Wildcard cert import keeps going into Primary Admin Node System Certs
rcullum
Level 4
Level 4
Hi, This is a  v2.7 Patch 7 ISE deployment. I'm trying to import a wildcard cert to use across both my ISE Nodes.in a standard 2 Node deployment. But each time I try and import the Certificate as a wildcard, it 'greys' out the option of choosing between which nodes I want to install the certificate on and keeps adding it only into the Primary Admin Node System Certs list. I want it to go into the Secondary Admin  Node System Certs list as well. I want to use if for Portal purposes so it's got to be available on both Nodes.
To disable the node list is normal, as wildcard-certs always go to all nodes. At least this is how it should work.
I had a TAC case open (also 2.7 but I don't remember which patch) where this also didn't work. The only solution was to remove the problematic node from the deployment and re-add the node. After that I was able to import the wildcard-certificate to both nodes as expected.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
