Wired Guest with SM-X-ES3D-48-P module
trcolber
Hi Team,
I have a customer who is trying to do wired redirection for guests with a SM-X-ES3D-48-P
ether-switch module running in a 4351 ISR router and it is not working. Per our ISE 1.3 documentation
http://www.cisco.com/c/en/us/td/docs/security/ise/1-3/compatibility/ise_sdt.html#pgfId-55038,
this module is only supported in a 4451-X running IOS-XE 3.11 code for
guest. He is running isr4300-universalk9.03.16.00
.S.155-3.S-ext .SPA.bin on the router and 15.2(3)E2 on the module. The cx would like to know
if this module is supported in the 4300 ISR with ISE? If not, are there plans to have it supported.
Timothy Abbott
Tremesha,
That code version on the module is basically the same code that the 3750X/3560X runs. I recommend opening a TAC case to determine root cause for the issue.
-Tim
Timothy Abbott
Tremesha,
-Tim
