wireless Authentication problem in ISE version 2.0.0.306
mostafashoaei
Hi guys,
I had a Cisco ISE 2.0.0.306,
I config authentication on wired and wireless, wired authentication works exactly, however wireless authentication gave following problem:
Failure Reason:  12321 PEAP failed SSL/TLS handshake because the client rejected the ISE local-certificate
Resolution:      Check whether the proper server certificate is installed and configured for EAP in the Local Certificates page ( Administration > System > Certificates > Local Certificates ). Also ensure that the certificate authority that signed this server certificate is correctly installed in client's supplicant. Check the previous steps in the log for this EAP-TLS conversation for a message indicating why the handshake failed. Check the OpenSSLErrorMessage and OpenSSLErrorStack for more information.
Root cause:     PEAP failed SSL/TLS handshake because the client rejected the ISE local-certificate
I have been attached screen shot of error, please attention to it.
note: I have run a new version of Cisco ISE(2.2.0.470) and works exactly.
both of ISE have same configuration.
I have changed the certificates of ISE but it doesn't work still.
Can you tel me, whether this is a bug in this version?
please help me,
Thanks a lot
smashash
Try to  install the ISE server certificate or root certificate in client (supplicant) side.
Or
If you are using MSFT PC (windows), you can disable the server validation option on PC.
see attached file
