Wireless Guest Portal with Device registration
pemasirid
I have configured the ISE for wireless guest authentication. Once i got the guest portal and enter usernam/password, it redirecting to Self Provisioning portal for  Device Registration. (attached)
I have unchecked the option "enable my device portal" under My Device-->Portal configuraiton (attached)
Can someone please advise, why I'm still getting Self provisioning portal, although I might need this later for On-board provisioning, at this time I just want guest user authentication and allow access to internet.
Thanks in advance.
descalante2007
I think you should disable in the DefaultGuestPortal (Administration >> Web Portal Management >> Settings >> Guest >> Multi-Portal Configurations >> DefaultGuestPortal >> Operations  .... Uncheck the option Enable Self-Provisioning Flow
Daniel Escalante.
