Xsupplicant wired issue
chiheb278
Community Member
I've installed & configured xsupplicant on RHFC1 but an error is accured :
Error for wireless request "Set ESSID" (8B1A) :
SET failed on device eth0 ; Operation not supported.
I would like to run PEAP on linux in a wired LAN
Help me !
jsivulka
Level 10
Level 10
To add to my previous answer, you should have a look at http://openwrt.org/logs/wrt54g.log.20041013 which I found through google search. It will throw some light on the issue.
