problem activate VM in router ISR 4321 cisco
Dhikra Marghli
Level 5
Level 5
Hello
I have ISR 4321  and i nstall fedora.ova  and i put this configuration :
Router(config)#virtual-service
Router(config-virt-serv-global)#virtual-service fedora
Router(config-virt-serv)#ac
Router(config-virt-serv)#activate
% Virtual service ubuntu install has not completed, please activate the VM after install is completed
so i delete  file  fedora.ova and i try to install ubuntu.ova
Router(config-virt-serv-global)#virtual-service ubuntu
it show the same problem and the same message error  !!!??
Router#dir bootflash:
Directory of bootflash:/
342049 drwx 28672 Dec 14 2020 08:09:24 +00:00 tracelogs
358337 drwx 4096 Dec 14 2020 08:04:09 +00:00 virtual-instance
15 -rw- 344320000 Dec 14 2020 07:43:14 +00:00 ubuntu-18.04-server-cloudimg-amd64.o va
260611 drwx 4096 Dec 14 2020 07:34:53 +00:00 SHARED-IOX
325762 drwx 4096 Dec 14 2020 07:34:51 +00:00 license_evlog
14 -rw- 30 Dec 14 2020 07:34:47 +00:00 throughput_monitor_params
18 -rw- 134458 Dec 14 2020 07:34:31 +00:00 memleak.tcl
16289 drwx 4096 Dec 14 2020 07:34:29 +00:00 .prst_sync
17 -rw- 1182 Dec 14 2020 07:34:04 +00:00 mode_event_log
162881 drwx 4096 Dec 14 2020 07:33:25 +00:00 sysboot
374626 drwx 4096 Dec 10 2020 10:16:10 +00:00 .dbpersist
260610 drwx 4096 Dec 10 2020 09:48:46 +00:00 onep
20 -rwx 1314 Dec 10 2020 09:48:13 +00:00 trustidrootx3_ca.ca
19 -rw- 20109 Dec 10 2020 09:48:13 +00:00 ios_core.p7b
325761 drwx 4096 Dec 10 2020 09:38:48 +00:00 gs_script
16 -rw- 703643960 Dec 10 2020 09:11:54 +00:00 isr4300-universalk9.17.03.02.SPA.bin
97729 drwx 4096 Feb 18 2019 07:21:10 +00:00 core
13 -rw- 0 Feb 18 2019 07:19:41 +00:00 tracelogs.271
81441 drwx 4096 Feb 18 2019 07:19:32 +00:00 .rollback_timer
12 -rw- 486645440 Feb 18 2019 07:08:13 +00:00 isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin
260609 drwx 4096 Feb 18 2019 06:59:24 +00:00 .installer
11 drwx 16384 Feb 18 2019 06:58:26 +00:00 lost+found
3149967360 bytes total (775741440 bytes free)
Router#
Router#show virtual-service list
Virtual Service List:
Router#show running-config interface virtualportGroup 1
Building configuration...
Current configuration : 103 bytes
interface VirtualPortGroup1
description managment-Interface
ip address 10.0.0.1 255.255.255.0
end
Router#sho
Router#show run
Router#show running-config | sec
Router#show running-config | section virtual-ser
Router#show running-config | section virtual-service
virtual-service
signing level unsigned
virtual-service install
virtual-service rest_api
vnic gateway VirtualPortGroup2
guest ip address 20.0.0.3
vnic gateway VirtualPortGroup1
guest ip address 10.0.0.2
Router#
so i need a solution for this  problem and for this message error :
% Virtual service ubuntu install has not completed, please activate the VM after install is comp leted
i wait a reply from expert VM and expert router 4321 !!
thanks
Dhikra Marghli
Level 5
Level 5
i want a help and i wait a answer
please some one expert VM  can answer me !!
