Network Devices
Explore, inquire, and collaborate on network devices.
IOS XE DevCenter
YANG Suite
Sandboxes & Learning Labs
>> View previously featured conversations <<
HelloCurrently building a script to bulk audit a network of over 700 switches to compile an IP and VLAN schema. All going well except I’m getting the below error for 4 switches:Connecting to <host> (x.x.x.x)...Failed to connect to <host> (x.x.x.x):Pa...
MerakiGnome by • Meraki Community All-Star
  • 2140 Views
  • 6 replies
Hallo!I have a 9300 im trying to get the guestshell up and running. Specifically its external communications that im struggeling with.app-hostingappid guestshell  app-vnic AppGigabitEthernet trunk   vlan 4094 guest-interface 0    guest-ipaddress 192....
trondaker by • Level 6
  • 1364 Views
  • 5 replies
Hello,I was running the following playbook; the purpose is to run ping checks of virtual IPs on a Cisco 7K switch.So far so good. However, when I wanted to expand the playbook by also counting the successful ping.Running the runbook again I receive t...
Netmart by • Level 7
  • 1410 Views
  • 1 replies
When I install an OVA with the example yaml file, it builds an xml file with the default cpu mode (qemu) which is basically defunct now.  It is not possible to run RHEL9/OL9 with the qemu cpu.  Is it possible to specify an alternate cpu mode - host-p...
thock by • Visitor
  • 1672 Views
  • 2 replies
Does anyone know if it is hiding somewhere, or how to get some updated firmware for the old Exanic x4 SmartNIC? It doesnt look like it was ever given a cisco name like the Cisco Nexus SmartNIC K35-S (x10). It looks like there was an update in 2017 an...
GoPreaux by • Community Member
  • 1384 Views
  • 0 replies
