01-30-2025 05:48 AM
Hi everyone,
I have a device XR 7.0.1 (IOSXRV9000). I wanted to set up dial-out event driven (on-change) telemetry.
Is there a list or way to find out which module/path support this feature?
I tried this:
| State: ACTIVE Source Interface: MgmtEth0_RP0_CPU0_0(Up 0x60000000) Sensor groups: Id: interfaces Sample Interval: 0 ms Sensor Path: Cisco-IOS-XR-pfi-im-cmd-oper:interfaces Sensor Path State: Resolved |
I got the first full response when my router connected to collector. But when I changed description, notification was not received. I also checked the "no of packets sent" in router which was not changed.
Thanks for help!
01-30-2025 07:49 AM
Event-driven-telemetry is supported for limited number of sensor-paths, and this sensor path is not supported.
01-30-2025 09:12 AM
Hi @rahusha7
thanks for your inputs.
Is there any list or method to find if a given sensor path supports dial out Event-driven-telemetry?
01-30-2025 09:27 AM
There is a list of sensor-paths that support EDT on latest XR version. Let me know if you are interested.
01-30-2025 09:32 AM
XR 7.0.1 would be better but I will take whatever info you have. Probably try some of the paths if supported in the old version.
01-30-2025 09:01 PM - edited 01-30-2025 09:29 PM
Hi @rahusha7
Please provide the list for the latest version.
Also any lead on the XR 7.0.1 supported list will be appreciated. Even one path which is supported on this version will help us.
06-26-2025 08:37 PM
I'm late but chiming in here to hopefully share insight since I had the exact same question!
Per Cisco documentation, "For the nodes that support event-driven telemetry (EDT), the YANG model is annotated with the statement xr:event-telemetry. For example, the interface that supports EDT has an annotation as shown in the following example:
leaf interface-name {
xr:event-telemetry "Subscribe Telemetry Event";
type xr:Interface-name;
description "Member's interface name";
Looking at the YangModels github, I don't see any references to "xr:event-telemetry" so I might be misunderstanding something. That said, I found an xrdocs article explicitly specifying a couple paths, though it's from 2019. (Source)
(I found this by searching "xrdocs" "EDT" (yes include the quotes) in google so feel free to try it yourself to see if any updated sources are ever released.)
06-26-2025 08:48 PM
Update: Just checked the top yang file from the screenshot I provided on the YangModels github and it actually explicitly mentions the following:
2020-09-03
Removed event-telemetry annotation from leaf interface-name of grouping BM-MEMBER-DATA
Soooo I'm not sure what the motivation for doing so was....
06-28-2025 12:31 PM - edited 06-28-2025 12:32 PM
Update: Found the telemetry notations in GitHub!
Using the information provided by a separate xrdocs article (https://xrdocs.io/design/blogs/2019-02-02-modernizing-ixp-design/), I found part of my issue.
I initially was looking at the parent module (E.g. https://github.com/YangModels/yang/blob/main/vendor/cisco/xr/792/Cisco-IOS-XR-controller-optics-oper.yang) when the "xr:event-telemetry" is under the submodule specifically (https://github.com/YangModels/yang/blob/main/vendor/cisco/xr/792/Cisco-IOS-XR-controller-optics-oper-sub1.yang)
Still trying to find any other indicators using pyang but if I'm able to and / or if I have the energy, I'll try to automate a way to print out all paths that include "xr:event-telemetry" in their yang file(s)!
12-09-2025 06:49 AM
I’m having a similar issue where a few sensor paths work with EDT, but none of the routing-protocol paths do. Is there a list we can check to confirm which sensor paths and versions are supported?
