2 ISP switching
sanjar200994
Hello, I'm not so experienced network admin. So I have a question
at the moment switching ISPs on the router is done using tracks.
Part of config
track 10 ip sla 10 reachability
track 11 ip sla 11 reachability
track 15 list boolean and
object 10 not
object 11 not
delay down 60 up 60
track 20 ip sla 20 reachability
track 21 ip sla 21 reachability
track 25 list boolean or
object 20
object 21
delay down 60 up 60
track 30 list boolean and
object 15
object 25
ip route vrf ISP 0.0.0.0 0.0.0.0 Dialer1 4 track 30
ip route vrf ISP 0.0.0.0 0.0.0.0 Dialer0 10
event manager applet backup
event track 30 state up
action 1.0 cli command "configure terminal"
action 1.1 cli command "interface range tunnel0-1"
action 1.2 cli command "shutdown"
action 1.3 cli command "no tunnel protection ipsec profile"
action 1.4 cli command "tunnel source Vlan5"
action 1.5 cli command "tunnel protection ipsec profile profile-a shared"
action 1.6 cli command "no shutdown"
action 1.7 cli command "end"
action 1.8 cli command "exit"
event manager applet main
event track 30 state down
action 1.4 cli command "tunnel source Dialer0"
on my previous job we used 2 different vrf, example config below
ip vrf INET1
 rd 10:10
ip vrf INET2
 rd 100:100
 crypto ipsec profile DMVPN
 set transform-set AES256-SHA
 set pfs group2
crypto ipsec profile DMVPN2
 set pfs group2
interface Tunnel0
 ip address XXX.XXX.11.XXX 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip hello-interval eigrp 77 4
 ip flow ingress
 ip flow egress
 ip nhrp network-id 11111
 ip nhrp holdtime 300
 ip nhrp shortcut
 ip nhrp redirect
 ip tcp adjust-mss 1360
 load-interval 30
 <b>delay 10 </b>
 if-state nhrp
 tunnel source <Internet Interface1>
 tunnel mode gre multipoint
 tunnel key 999999
 tunnel vrf INET1
 tunnel protection ipsec profile DMVPN
interface Tunnel1
 ip address XXX.XXX.12.XXX 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp authentication XYZXYZ
 ip nhrp network-id 22222
 ip nhrp shortcut
 ip nhrp redirect
 ip tcp adjust-mss 1320
 load-interval 30
<b> delay 5000</b>
 if-state nhrp
 tunnel source <Internet Interface2>
 tunnel key 888888
 tunnel vrf INET2
 tunnel protection ipsec profile DMVPN2
router eigrp 77
 network XXX.XXX.11.XXX
 network XXX.XXX.12.XXX
exit
ip route vrf INET1 0.0.0.0 0.0.0.0 <Internet Interface1> <GW Address1> name INET1
ip route vrf INET2 0.0.0.0 0.0.0.0 <Internet Interface2> <GW Address2> name INET2
SO QUESTION IS - which kind of switching is better?
I am not sure what the boolean tracking is for exactly, but the second (EIGRP-based) option looks better, since the failover is much faster.
