3550 - using SNMP to apply configuration changes
rmosely
I'm working on rolling out minor config
changes to the running-config on about
50 3550 24 port switches.
Using "How To Copy Configurations To and From Cisco Devices Using SNMP" and other sources, I am able to set ccCopyProtocol.<random number> integer 1
ccCopySourceFileType.<Random number> integer 1 and
ccCopyDestFileType.<Random number> integer 3
But I can not set
ccCopyServerAddress.<Random number> ipaddress "<server ip address>"
OR
ccCopyFileName. <Random number> octetstring "<file name>"
OR
ccCopyEntryRowStatus.<Random number> integer 4.
And snmpget on these OID's return the
error that:
"Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: SNMPv2-SMI::enterprises.9.9.96.1.1.1.1.5.26"
Is it possible to use snmp to trigger a
copy from a tftp server to the running-config on the switch?
Ray Mosely
Network Specialist
Arizona Schools for the Dead and Blind
Tucson, AZ
15 Replies 15
I'm not sure, after getting ribbed about my typing skills, if I should ask which parameter it was that I lost? (line 1 last post, I mean lost post).
Thanks to everyone for all the help,
Ray ;-)
