acceptable DHCP latency
ariesc_33
what is the acceptable DHCP latency using 1 GB interface and 2000+ pool (clients). anyone has documentation regarding this?
miheg
Level 5
Level 5
Depends on the timeout on the DHCP client.
Maybe its part of the DHCP RFC?
What makes you think the server is slow?
Most "DHCP problems" come from switchport where the client connects because the portfast or set port host command was forgotten.
Cheers,
Michel
no slow down encountered so far, just want to know what threshold will i set for DHCP latency..thanks
