ACS 5.1 Authentication against AD problem
nrmdcs
I have a pair of ACS 5.1 virtual appliances in a master/slave configuration, running build 5.1.0.44.  We have it configured to authenticate TACACS against Active Directory, but have run into a problem with the account of one my colleagues.  His account password recently expired and since changing it he is no longer able to authenticate on devices pointing to the master ACS server, but has no issue with devices pointing to the slave ACS server.  Several other users have changed their passwords in AD and have not encountered this problem.
ACS View shows the following error in the TACACS+ authentication log:  "24421 Change password against Active Directory failed since it is disabled in configuration".  The account we use to connect to active directory does not have permission to send password changes, so I have disabled changing passwords in the AD identity store configuration.  As a test, I enabled password changing and instead saw this error:  "24407 User authentication against AD failed since user is required to change his password".
I've had him change passwords numerous times, try different SSH clients, and different PCs.  I also had him lock his account out, and then try logging on and instead was presented with this error: "24415 User authentication against AD failed since user's account is locked out".  So it seems that ACS is correctly querying AD but seems to be caching the fact that his account has expired.
The only difference between the two ACS servers are that they are querying different AD servers.  I've gotten our AD team to reset his password, check that his account is not locked on a particular AD server, and that replication is functioning.  I've also restarted the services and cold started the ACS virtual machine to no effect.  I have yet to try clearing the AD configuration and re-entering it.
show logging application acs reveals the following:
ActiveDirectoryClient,19/10/2011,08:46:25:307,WARN ,3032882080,cntx=0000253027,sesn=ciscoacslc/108180474/33226,user=parrishg,[ActiveDirectoryClient::isLRPC_ConnectionError] Retryable error 6 (LRPC failed) received. Tr
ying to reconnect.,ActiveDirectoryClient.cpp:2429
ActiveDirectoryClient,19/10/2011,08:46:25:311,WARN ,3032882080,cntx=0000253027,sesn=ciscoacslc/108180474/33226,user=parrishg,[ActiveDirectoryClient::plainTextAuthenticate] PAP authentication for user: parrishg has fai
led due to error: 16:Password expired,ActiveDirectoryClient.cpp:994
ActiveDirectoryClient,19/10/2011,08:49:27:468,WARN ,3031829408,cntx=0000253057,sesn=ciscoacslc/108180474/33228,user=parrishg,[ActiveDirectoryClient::isLRPC_ConnectionError] Retryable error 6 (LRPC failed) received. Tr
ActiveDirectoryClient,19/10/2011,08:49:27:475,WARN ,3031829408,cntx=0000253057,sesn=ciscoacslc/108180474/33228,user=parrishg,[ActiveDirectoryClient::plainTextAuthenticate] PAP authentication for user: parrishg has fai
ActiveDirectoryIDStore,19/10/2011,08:49:27:475,ERROR,3031829408,cntx=0000253057,sesn=ciscoacslc/108180474/33228,user=parrishg,ActiveDirectoryIDStore::onPlainAuthenticateAndQueryEvent - User password expired but change
password configuration is disabled - authentication failed,ActiveDirectoryIDStore.cpp:525
I am aware that I can upgrade to 5.1.0.44.6 and intend to do so (although CSCsr81297 concerns me as we make extensive use of AD for authentication), but I don't know that there is any guarantee that this will fix it.
Any ideas on what might be the cause, and how I can fix this?
Thanks!
0 Replies 0
