addind syslog scripts to PI 3.8 (CSCvo85645)
Ditter
Level 4
Level 4
Hi to all,
i can not find any documentation about running scripts for syslog events in Cisco Prime 3.8.
I found the following bug by searching in google:
Bug SearchCSCvo85645
Help | Feedback Feedback
PI 3.5.x: Documentation required to use custom scripts while creating syslog policies.
CSCvo85645
Description
Symptom:
Prime infrastructure latest version have create ,delete and modify syslog policies.
one of the option provided is to upload scripts while creating policies.
it is mentioned that "Each scripts will be executed with corresponding parameters"
But what is missing in documentation are:
1. How to create/configure a syslog script.
2. what are parameters supported.
Conditions:
Customer using upload scripts for creating syslog policy.
Workaround:
NA
Does somebody have any suggestions about these scripts that can  be uploaded to PI , in order to run them when a syslog event occurs?
Thank you,
Ditter.
Ditter
Level 4
Level 4
Hi to all,
As the situation is the same from prime 3.5 (as bug details note) and now we are at prime version 3.8, did someone ever needed to use these syslog scripts or found any cisco documentation about them in order to share with us?
Ditter
Hi to all,
perhaps any idea of what kind these syslog scripts are?  For example, are these tcl scripts or EEM type scripts?
Ditter.
