Applet - File not being written
Hiram Morlan
Hi everyone,
I have an applet configured to monitor CPU going above 50%, this was working previously but it suddenly stopped appending on the file. The file system has space on it. I also did a show "show clock - append sup-bootdisk:TEST-CLOCK.tx" and it worked. The event manager registers the event but it doesn't write. Here is my config:
event manager scheduler script thread class default number 1
event manager applet high_CPU
 event snmp oid "1.3.6.1.4.1.9.9.109.1.1.1.1.10" get-type next entry-op ge entry-val "50" exit-op le exit-val "5" poll-interval 5
 action 0.0 syslog msg "High CPU  DETECTED. Please wait  logging Information to sup-bootdisk:high_cpu_BOTMAN01.txt"
 action 0.1 cli command "enable"
 action 0.2 cli command "term exec prompt timestamp"
 action 0.3 cli command "term len 0"
 action 1.1 cli command "show clock | append sup-bootdisk:high_cpu_BOTMAN01.txt"
 action 1.2 cli command "show processes cpu sorted | append sup-bootdisk:high_cpu_BOTMAN01.txt"
 action 1.3 cli command "show processes cpu detailed | append sup-bootdisk:high_cpu_BOTMAN01.txt"
 action 1.4 cli command "show ip route summary | append sup-bootdisk:high_cpu_BOTMAN01.txt"
 action 1.5 cli command "show ip route | include 00:00: | append sup-bootdisk:high_cpu_BOTMAN01.txt"
 action 2.0 cli command "end"
show event manager history events
No.  Time of Event             Event Type          Name
1    Wed Oct25  01:08:51 2017  snmp                applet: high_CPU
2    Thu Oct26  13:42:52 2017  snmp                applet: high_CPU
3    Sat Oct28  01:06:09 2017  snmp                applet: high_CPU
4    Mon Oct30  01:08:02 2017  snmp                applet: high_CPU
5    Mon Oct30  09:18:26 2017  snmp                applet: high_CPU
6    Mon Oct30  09:29:46 2017  snmp                applet: high_CPU
7    Mon Oct30  09:31:26 2017  snmp                applet: high_CPU
8    Mon Oct30  09:32:21 2017  snmp                applet: high_CPU
9    Mon Oct30  09:32:31 2017  snmp                applet: high_CPU
10   Mon Oct30  09:41:42 2017  snmp                applet: high_CPU
The device is a 6504-E running 12.2(33)SXH6
Joe Clarke
If you have AAA command authorization configured, it could be blocking the commands.  Enable "debug event manager action cli" and see what output you get.
Vinit Jain
Hi Hiram
Could you please paste the output of "show file system". Just want to make sure if you have sup-bootdisk: or sup-bootflash:.
Also, could you please perform the below test:
copy run sup-bootdisk:startup-config.txt
--Vinit
Hi Vinit,
File Systems:
       Size(b)       Free(b)      Type  Flags  Prefixes
             -             -    opaque     rw   system:
             -             -    opaque     rw   tmpsys:
             -             -    opaque     ro   flexwan-fpd:
*    511705088     511705088      disk     rw   disk0:#
             -             -      disk     rw   disk1:
     512024576     157442048      disk     rw   sup-bootdisk: sup-bootflash:#
      73138346             0    opaque     ro   sup-microcode:
             0     199835804    opaque     wo   sup-image:
        129004        128208     nvram     rw   const_nvram:
       1964024       1939175     nvram     rw   nvram:
             -             -    opaque     rw   null:
             -             -    opaque     ro   tar:
             -             -   network     rw   tftp:
             -             -    opaque     wo   syslog:
      65536000      65196656     flash     rw   bootflash:
             -             -   network     rw   rcp:
             -             -   network     rw   ftp:
             -             -   network     rw   http:
             -             -   network     rw   scp:
             -             -   network     rw   https:
             -             -    opaque     ro   cns:
      32055296      32055296     flash     rw   ssc4-disk0:
      15990784      15990784     flash     rw   dfc#2-bootflash:
#copy running-config sup-bootdisk:startup-config.txt
Destination filename [startup-config.txt]?
19846 bytes copied in 2.888 secs (6872 bytes/sec)
Joe Clarke
Hi Joe,
Thanks for your help
I activated the debug, I see Command Authorization Failed. I entered "event manager session cli username <username>", let's hope that fixes it.
