Assistance with RESTCONF API Call
JamesMathis
Can someone tell me how to add an IP Subnet to a network-object using RESTCONF?  I have no issues with adding an IP, but I get a 400 error when trying to add a subnet.
I am using an HTTP client to make this call.  The parameters as as follows:
URL:
https://X.X.X.X/restconf/data/Cisco-IOS-XE-native:native/object-group/Cisco-IOS-XE-object-group:network=blacklist_sources/obj-Mode-config-network-group/host
HTTP Method:
PATCH
Headers: Content-Type - application/yang-data+json
Authorization Basic XXXXXXXXXXXXXXXXXXXXXXXXXXXX
Body:
{"Cisco-IOS-XE-object-group:host":[{"ipv4-host":"1.2.3.0 255.255.255.0"}]}
This is the error message I receive.
{"errors":{"error":[{"error-message":"missing element: ipv4-host in /ios:native/ios:object-group/ios-og:network[ios-og:name='blacklist_sources']/ios-og:obj-Mode-config-network-group/ios-og:host","error-path":"/Cisco-IOS-XE-native:native/object-group/Cisco-IOS-XE-object-group:network=blacklist_sources/obj-Mode-config-network-group/host","error-tag":"malformed-message","error-type":"application"}]}}
Dan Frey
Try this.
curl -k -v -X PATCH -u dafrey:xxxxxxx -H 'Content-Type: application/yang-data+json' \
https://192.168.0.20/restconf/data/Cisco-IOS-XE-native:native/object-group/Cisco-IOS-XE-object-group:network=blacklist_sources/obj-Mode-config-network-group/network_address \
--data '{"network_address": [{"ipv4_addr": "10.2.1.0", "ipv4_mask": "255.255.255.0" }]}'
Dan Frey
Try this.
Andrea Testino
James,
Based on the below YANG model, you may want to try network_address since you're adding a subnet as opposed to ipv4-host. Request below:
curl -X 'PATCH' \
  'https://<IP_ADDRESS>:443/restconf/data/Cisco-IOS-XE-native:native/object-group/Cisco-IOS-XE-object-group:network=,/obj-Mode-config-network-group/network_address' \
  -H 'accept: application/yang-data+json' \
  -d '{
      "ipv4_addr": "1.2.3.0",
 YANG model:
(yang-test-venv) atestini@ATESTINI-M-R61B 1791 % pyang -f tree Cisco-IOS-XE-object-group.yang
module: Cisco-IOS-XE-object-group
  augment /ios:native/ios:object-group:
    +--rw network* [name]
    |  +--rw name                             string
    |  +--rw obj-Mode-config-network-group
    |     +--rw network_address* [ipv4_addr ipv4_mask]
    |     |  +--rw ipv4_addr    inet:ipv4-address
    |     |  +--rw ipv4_mask    inet:ipv4-address
    |     +--rw description?       string
    |     +--rw group-objects* [network-group]
    |     |  +--rw network-group    -> /ios:native/object-group/ios-og:network/name
    |     x--rw group-object?      string
    |     +--rw host* [ipv4-host]
    |     |  +--rw ipv4-host    inet:host
    |     +--rw addr-ranges* [addr-range-start addr-range-end]
    |     |  +--rw addr-range-start    inet:ipv4-address
    |     |  +--rw addr-range-end      inet:ipv4-address
    |     x--rw range
    |        x--rw ip-addr-min?   inet:ipv4-address
    |        x--rw ip-addr-max?   inet:ipv4-address
    <snip>
Hope that helps!
- Andrea, CCIE #56739 R&S
