Backup issue in LMS 3.2
thongams2000
I am trying to take a complete backup on LMS 3.2. The backup folder only contains a single forder for cmf. I am not able to see any other files or folders like cwportal or rmeng. Need suggestions.
Following is the output -
C:\Program Files\CSCOpx\bin>perl backup.pl E:\backup30
Backup to 'E:/backup30' started at: [Thu Oct 24 10:03:46 2013]
[Thu Oct 24 10:03:48 2013] WARNING: All previously backed-up data in the specified backup folder wil
l be replaced with the new data.
processed dir: E:\backup30\0
processed dir: E:\backup30\0\cmf
processed file: E:\backup30\0\cmf\cmfversion.info
[Thu Oct 24 10:03:49 2013] Backup completed: at [Thu Oct 24 10:03:49 2013]
AFROJ AHMAD
Hi Soniya,
what folders you have under NMSROOT/CSCOpx/backup  , if you found  MANIFEST folder then share the screen shot of that..
Share the  dbbackup.log
Thanks-
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Afroz,
I can see one folder rmeng under NMSROOT/CSCOpx/backup. PFA the screenshot and the dbbackup.log.
Soniya
Hi Soniya,
ERROR(364): No database files are available for the installed applications; nothing to back up.
As you can see the error above which I have found from dbbackup.log .
Check if you have Sever backup or any other Good Known backup when everything was fine then you can restore that backup otherwise you need to uninstalled and Installed LMS again
Thanks-
Afroz
[Do rate the useful post ]
