Bandwidth monitoring on a Catalyst 2960
ruben
Hello all, I'm working with two Catalyst 2960 switches and I would like to know if there is a way to monitor bandwidth on individual ports. Ideally I would like to have one graph showing a bandwidth usage reading on each port. I tried using the Network Assistant to accomplish this, but I was only able to view one port at a time. I also tried using a traffic graphing program from Paessler, but a MIB file is needed to allow the program to connect to the switch. When I ran a search on the network management page the 2960 was not on the list for MIB supported products. Is this type of graph possible to do? Or is there a more effective way to accomplish what I would like to do. Any ideas or suggestions would be helpful.
mnorwood
If you just want simple historical graphs for each port, I would use MRTG.
http://oss.oetiker.ch/mrtg/
Hi, we have just swapped all our avaya switches with catalyst 2960 (12, 24 and 48 ports) and 3750 (48 ports with 10gig module).
How do I find what port I should monitor for bandwith graphs?
Target[10.0.0.22_loc1]: 1:@10.0.0.22:
