BBSM - multiple sites - same VLAN
steinbasma
We have two customers sharing a BBSM, and they want to use it for auditing guest wireless access. For several reasons these two customers want separate sites and separate subnets for their wireless guest, but they share a Catalyst 6513 as the switch/router the BBSM is connected to.
The 6513 has implemented the two different subnets in a shared VRF, and we have set up the BBSM to talk to the two different router interfaces. In this scenario, as far as I can understand, we have to use NULL switches. But the BBSM won't let us define a second NULL switch. What are we doing wrong.
Thanx for any help
sathappan
I suppose that you are having two vlans. If you are having two vlans or multiple vlans, try creating a router for each vlan with the router ip address as the vlan management ip address and create a null switch for each rouer.
hope this helps
thanks
sathappan.s
