C6500 sup720 Netflow
ruben.montes
I want to configure Netflow in a C6500 with sup720, PFC3 and MSFC3 with IOS 12.2(18)SXD2 to send the export information to a NAM. I've been reviewing some documention but it is not very clear about what is supposed I should configure. Can I enable mls netflow during working hours or should I take any precaution? Netflow is only a method of gathering flow data isn't it? I assume it wouldn't affect the switching method the device is using (CEF,dCEF, etc): is that correct?
CAn anyone help me?
Thanks in advance,
Ruben
hgru
I am having the same problem! only with a 6500 doeing CEF on a supervisor2 with MFSC and a switch fabric module.
I thing i should be possible seeing some online e-learning.
Go to the partner e-learning section (if you have access) and do a seach on netflow.
follow the presentations calles netflow basics and anvanged.
Please update this post if you find info or have switched it on.
Hans
