Campus Manager producing SNMP authentication failure messages
Jeff Law
We are running LMS 2.6 across 3 Windows 2003 servers.
The server that is running Campus Manager seems to be querying our Cisco devices with the I presume the wrong community string as we are receiving SNMP authentication failure traps from these devices, and the offending device is our Campus Manager server.
The master DB is on another server and apart from Common Services, there are no other CisocWorks applications on this server.
I am 99% certain that the configs are correct on both the LMS servers and the devices as we can query the devices using SNMP from the servers.
The servers are multihomed, and I have checked that the production NIC is the one that is configured in the $NMSROOT\lib\vbroker\gatekeeper.cfg file
Also the IP address returned in the authentication failure trap is the production NIC.
ANy one else seen this sort of behaviour and managed to work it out?
Jeff
Joe Clarke
This can happen when User Tracking does its major acquisition sweep. Check your ANIServer.properties for the following two properties:
UTGetVlansWithUserPortsIOS=1
UTGetVlansOnDownPorts=0
That should prevent UT from querying unavailable VLANs. If the problem still occurs after verifying those two properties are set correctly, you will need to get a sniffer trace to figure out which objects are being queried, and which community string is being used.
I have checked these parameters and the UTGetVlansOnDownPorts was =1. I have changed this to be 0.
Do I have to restart anything, or will it reread this file automatically when it does the next sweep?
Jeff
PS Many thanks for your responses. It is greatly appreciated.
Correct, UTGetVlansOnDownPorts should be 0. You do not need to restart anything.
