Ccna i0v6 questions
daniel4579329
hi im learning for ccna and i wonder
1.1 hex digit 4 bit my question is this, could there be prefix that doesent divide by 4
2. Is there NAT in ipv6
3. If i want to use unique local what are the option in ipv6
2 Accepted Solutions
ngkin2010
Level 7
Level 7
1. Prefix or the subnet mask is counting bit by bit, not hex by hex. So it not necessary to be dividable by 4.
For example, fe80::0/126 is still a valid IPv6 subnet.
Add one more note here, although it's technically valid, it's not the best practice to assign /126 as prefix theoretically.
2.  Yes, there is NAT in IPv6 in certain products.
3. Not quite sure your question
does SLAAC and DHCP can be used on global unicast / unique local or both ?
You could them on both global unicast and unique local.
so if is see /53 how the format of the ipv6 will be?
/53 mean it's masking first 53 bits. For example:
Given an IPv6 address FD08:1111:2222:8888::9999/53
  [HEX]   F    D    0    8 :    1    1    1    1 :     2    2    2    2
 [BIN] 1111 1101 0000 1000 : 0001 0001 0001 0001 :  0010 0010 0010 0010
[MASK] 1111 1111 1111 1111 : 1111 1111 1111 1111 : 1111 1111 1111 1111 8 8 8 8 :: 9 9 9 9
1000 1000 1000 1000 :: 1001 1001 1001 1001 1111 1000 0000 0000 :: 0000 0000 0000 0000
The subnet ID for FD08:1111:2222:8888::9999/53 would be :
<------------------------------ 53 bits -------------------------------><--------------75 bits------------->
[BIN] 1111 1101 0000 1000 : 0001 0001 0001 0001 : 0010 0010 0010 0010 : 1000 1000 0000 0000 :: 0000 0000 0000 0000 /53
[HEX] FD08:1111:2222:8800::/53
6 Replies 6
ngkin2010
Level 7
Level 7
i will try to ask it in a better way
if the prefix length was /54 so the 8888 part of the ip would have been 8C00 ?
thanks for the help :)
Giuseppe Larosa
Hello @daniel4579329 ,
about unique local
see
https://tools.ietf.org/html/rfc4193
you can assign unique local prefixes to router interfaces using stateless autoconfiguration via neighbor discovery process.
I think it is also possible to deploy them using a DHCPv6 server.
Hope to help
Giuseppe
