checking port channel status with snmp
Yves-Buecking_2
I am looking for a way to check the status for channeling ports via snmp.
is there a perl script or at least the right MiB you can recommend ?
cheers
Yves
David Stanford
Depends on the device you have and if the mib is supported
How about the object pagpPortState from the CISCO-PAGP-MIB
ftp://ftp-sj.cisco.com/pub/mibs/v2/
