Cisco 6509-Logging
rpsrekhi3
I have a Syslog server configured in my network.The Cisco 6509 switch has been configured to send SNMP traps to the syslog server by using the command:
snmp-server host 10.40.70.1 public
Do i need to put in the following command as well :
logging 10.40.70.1
Dose'nt both the commands work the same way.
Thanks!
RPS
miheg
Level 5
Level 5
These are two different things
Traps are send to a trap receiver
makes it send traps
Syslog messages are send to the syslog server
logging 10.40.70.1
makes it send syslog
Cheers,
Michel
David Stanford
Remember that snmp and syslog are different protocols. SNMP is UDP 161/162 while syslog is UDP 514. As mentioned above they will have different configurations.
You could also try:
snmp-server enable traps syslog
This will send syslog messages as snmp traps
