Cisco LMS and GSS 4492 Appliance
tech_trac
I have added the GSS to DCR and the verification report shows the SNMP, ssh, enable by ssh is all Ok.
But on running Sync Archive via RME, I get the following error
Protocol ==> Unknown / Not Applicable
Selected Procotol with order --> SSH, TFTP
Execution Result:
CM0062 Polling GSS for changes to configuration
CM00 Polling not supported on PRIMARY STARTUP config, defaulting to fetch.
CM00 Polling not supported on PRIMARY RUNNING config, defaulting to fetch.
And the Archive Mgmt jobs shows as 'Partially Successful'.
What does partially successful mean ?
23 Replies 23
No, there is still no debugging here. Try restarting ConfigMgmtServer, and try again:
pdterm ConfigMgmtServer
pdexec ConfigMgmtServer
Please let know how to restart ConfigMgmtServer.
Is pdterm and pdexec a CLI command.
Yes. These should be run from a DOS prompt on the server.
I have attached the detailed log.
I have removed the actual configuration blocks from the log. Hope it doesn't prevent studying the problem.
Thanks.
There is a bug in the GSS platform code in RME in that it doesn't properly disable the pager. I can build a patch for you to try. If you open a TAC service request, and have your engineer contact me directly, I will send them the patch.
We have Cisco Shared Support with a Cisco Gold Partner. But we don't have SmartNet. Supposedly, we may not be able to raise a TAC case due to absence of SmartNet.
Is there any workaround for this bug ?
Thanks.
You would need SAS or Software and Support to open a case on LMS. The workaround is to leave:
terminal-length 0
In your global config at all times.
I filed CSCtb55607 to track this problem.
Great!. We will keep checking on this.
