Cisco Prime Infrastructure - Threshold for Custom MIB Polling
TunaDinc19328
Hello all,
we have Cisco PI 3.3 and we had configured custom mib polling for some incompatible firewalls and we can see the results on a general dashlet.
However, we would like to set a threshold for these parameters so that Prime can notify us if the parameters exceed the limit, but doesn't seem possible. That is simply a CPU threshold we would like to set for Cisco ASA 5520 series firewalls and the parameter we would like to set is "".
It's simply because 5520 series don't respond to cpmCPUTotal5minRev or cpmCPUTotal1minRev, so that we can't set CPU threshold as we did for 5500-X series firewalls.
Anyone has done something similar so far? Does 3.4 or 3.5 support this feature?
Thank you so much in advance.
Edit: Please find attached the parameters.
TunaDinc19328
I can confirm that not even the version 3.5 with with the latest patch installed doesn't support this feature.
It could have been really nice to be able to set threshold for Custom MIB Polling
