Cisco RV042 - Dual Wan Load Balancing - Secure Site (HTTPS) Trouble
garysmith84
PID VID : RV042 V03
Firmware Version : v4.0.0.07-tm (Aug 19 2010 19:19:50)
Ever since I setup my RV042 with load balancing using the Dual Wan system I have had trouble staying connected to some secure sites. After doing some searching I found that the potential issue is the IP change mid session.
"http://www.broadbandreports.com/forum/r25537589-Cisco-RV042-can-not-use-load-balancing-for-some-web-sites"
Although my interface is significantly different I was able to find the same area in my RV042 admin area however, it doesn't seem to work.
System Management
> Dual Wan
In Wan 1 & Wan 2 I have HTTPS and HTTPS Secondary all forwarded to use Wan 2 under Protocol Binding
This however has not managed to do anything at all for my network and every computer conneceted experiences the same HTTPS irregularities at some websites.
I'm sure I must be doing something wrong, but I don't know what it is.
Both incoming connections are from the same service provider although the plans are different.
Any help with this would greatly help me stop losing my mind trying to fight with my website control panel for 10 minutes to just login and get something done.
garysmith84
Any ideas or advice from anyone?
