cisco works LMS login error
tjacobjames
i got a small issue with my Cisco Works LMS 2.5.1 with 2.6 patch
i tryed to restart my LMS server and once it got restarted i am getting the loggin page but once loging is done i get a page
"You don't have permission to access /cwhp/LiaisonServlet on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
im trying to login using the admin username and password.
i checked the services all services are running except "CiscoWorks Daemon Manager" when i start is manually it gives me an error saying "The Cisco Works Daemon Manager service on Local Computer started and then stopped. Some services stop automatically if they have no work to do, for example, the performance Logs and Alerts service".
can anyone help me out how to solve this issue
David Stanford
What are all of the LMS Services set to in the Services in control panel?
The following should be automatic:
CiscoWorks Daemon Manager - Automatic
CWCS rsh/rcp service - Automatic
CWCS syslog service - Automatic
CWCS tftp server - Automatic
If IPM installed:
IPM Aging Server - Automatic
IPM DB Server - Automatic
IPM Naming Server - Automatic
IPM PM Server - Automatic
IPM Stopper - Automatic
Everything else should be set to manual
