Ciscoworks LMS 3.2 Processes down
Yousofzai
Hello all,
I have installed ciscoworks lms 3.2 on windows 2003.
The discovery ran successfully and the devices were added to dcr.
After a few days, the ciscoworks processes were automatically down.
“Processes NOSServer, CmfDbMonitor, FHServer, IPMProcess, Sysloganalyser, 1041, CTMJrmServer,
Interactor1, EDS-GCF, IPMOGSServer, CMFOGSServer, 1015, DFMOGSServer, UPMDbMonitor, ChangeAudit, Inventory Collector, CampusOGSServer, Interactor, TISServer, jrm, UTManager,
ConfigMgmtServer, DCRServer, PMCOGSServer, ICServer, EssentialsDM, InventoryCollector1, PTMServer, RMEOGSServer, UPMProcess are down” .
Why were the processes down?
What might be the solution?
Thanks and Regards
Yama
Joe Clarke
DCRServer went down.  You can try stopping and restarting Daemon Manager to see if that resolves things.  If the processes terminate again, post the dcr.log and DCRServer.log.
Thanks for your answer.
Unfortunately the problem still exists.
I attached the required files.
Thanks and Regards
Your Common Services database may be crashing.  What errors do you see in the Windows Event Viewer when this problem occurs?
