Ciscoworks LMS 3
josepho
Is there a way for me to do automatic configuration backup of my switches and routers using ciscoworks?
Sven Hruza
Level 4
Level 4
Yes, that is a key feature of ciscoworks!
Configure the Ciscoworks server as syslog server on your routers and switches.
The devices will send config-syslog messages to the server if you have configured severity level 5 (notifications) on the devices.
Ciscoworks will now collect all configurations automatically after you did a change on a device.
configuration:
logging 10.10.10.10
logging trap notification
it is useful to configure a source interface for logging on routers.
I think the command is (for example)
logging source-interface loopback0
This is not working for me. Can you point me to the direction for a document in this regards.
The Resource Manager Essentials (RME) component of CiscoWorks performs this function. See Chapters 8 and 14 in the User Guide: http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/4.3/user/guide/chgaud.html
