CNR 6.2.1 failed to synchronize
handoko.wiyanto
dear all,
i configured two cnr for simple failover scenario.i only used CNR as DHCP server.
i follow the user guide in http://www.cisco.com/en/US/docs/net_mgmt/network_registrar/6.2.1/user/guide/UG26_Fai.html
however, if the backup cnr is in empty i can synchronized the server for the first time. but after that, if i made some changes in dhcp area, and want to snychronize again, the changes that i make is not propagated to the backup server.
i tried to synchronize using web, and nrcmd, both fails.
any feedbacks are welcome,
thanks,
handoko
ebreniz
Level 6
Level 6
The 6.2 version of CNR has massive differences in the failover config. There are several more steps that need to performed before failover will be enabled.
Here are the steps:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/ciscoasu/nr/nr62/nru
g/ug26_fai.htm#wp1038632
On the failover-primary (assuming it is 6.2) you will need to create clusters, being certain to add username, password, scp port (1234), and ssh to optional. After you have 2 clusters defined, then go to dhcp -> failover, delete existing failover-pair. Hit create, give it a name, and use the drop down boxes to define which server is primary and
which is failover-backup. Hit add cluster. At this point you should be able to do a sync with failover partner. Go to dhcp -> failover -> sync. Select your mode, then hit REPORT. This should generate the list of changes. At the bottom, click on sync. At this point you need to RELOAD BOTH DHCP SERVERS.
