CNR on Centos 6 & DHCP service issue
pachhapur
Hi All,
   I tried to install the Cisco Network Registerar on Centos 6. When I start the services I see everything working fine. The DHCP service doesn't get started at all. There is a issue while starting it.
Please let me know how to trouble shoot this and is LDAP mandatory for DHCP service to be started ?
-Amar
pachhapur
Could some one provide me some inputs on this installation. I have provided all the necessary license and still the DHCP service is not starting. The Version of the CNR is 7.2 which is latest I believe. Will this version work on Centos 6 ? If yes then what is wrong with DHCP service. If this doesn't work on Centos 6 then I need to change the OS.
Please help.
-Amar
Amar,
I had similar problem when trying to run CNR on 64-bit CentOS (though it was 5.7). After I changed to 32-bit OS version everything went fine.
Hope this helps.
Dmitry
u403185
Dear Amar,
i had exactly the same issues. After reading more or less Cisco Doku i found a small hint on a cisco web site.
---- snip ----
Red Hat Linux Installation
Installing Network Registrar on Red Hat Linux requires that you install the 32-bit OpenLDAP library; otherwise, the DHCP server may fail to start.
---- snap ----
In addidtion the install routine requested sun-java also in 32bit version.
So after all it runs on a 64Bit CentOS6 with these two 32bit applications.
Kind regards
Maik
