Configuration of a cisco c921-4P and two switchs SG250
ben.r.fr
Do any of you have skills in the Cisco ISR 900 Series?
I am setting up a network infrastructure with a c921-4P router and two Cisco SG250 switches. All devices are new and without any configurations on them.
when I wanted to create my sub-interfaces on the trunk port of the router, I understood that it was not possible because the ISR 900 series manages its LAN ports like a switch.
I'm in a bad place because my work to get to this point is totally broken now.
My questions are to find a solution and a good process to make my infrastructure available to manage four Vlans distributed on the two switches having the c921 router as master.
I've searched a lot but haven't found any good answers so far:
- Should I create a VTP configuration on the router to be the server and configure both switches to be clients?
- If not, what should I do?
- I have trouble understanding how to do the wiring?
- And I have trouble understanding how the router part works?
Thank you in advance for your feedback
Benjamin
3 Accepted Solutions
below is a basic configuration for the 921. Coonect the SG250 switches to an RJ-45 LAN port, and GigabitEthernet 5 to the ISP router/modem.
Current configuration : 1087 bytes
! No configuration change since last restart
! NVRAM config last updated at 06:11:03 UTC Mon Sep 17 2018
version 15.8
hostname C921
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
license udi pid C921J-4P sn PSZ22241C1T
redundancy
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8
interface GigabitEthernet0
description Link to SG250_1
switchport access vlan 1
interface GigabitEthernet1
description Link to SG250_2
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet5
description Uplink to ISP
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet5 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet5 dhcp
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
vstack
line con 0
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
if you need several Vlans, create the Vlan interfaces on the router, and the GigabitEthernet interfaces on the router that connect to the swtches as trunks.
the default router IP addresses configured in your DHCP pools need to be the same as the Vlan interface IP addresses:
Current configuration : 1826 bytes
! Last configuration change at 16:30:12 UTC Tue Feb 22 2022 by
version 15.8
hostname RZA
boot-start-marker
boot-end-marker
enable password
no aaa new-model
ip dhcp excluded-address 192.168.x.1 192.168.x.15
ip dhcp excluded-address 192.168.x.1 192.168.x.22
ip dhcp pool vlan_
network 192.168.x.0 255.255.255.0
default-router 192.168.x.1
dns-server 8.8.8.8
ip dhcp pool vlan_*****
network 192.168.y.0 255.255.255.0
default-router 192.168.y.1
dns-server 8.8.8.8
ip dhcp pool vlan_
network 192.168.z.0 255.255.255.0
default-router 192.168.z.1
dns-server 8.8.8.8
ip domain name
ip cef
no ipv6 cef
license udi pid C921-4P sn PSZ25521HCQ
username password 0
redundancy
description link to ODB
switchport trunk native vlan 199
switchport mode trunk
no ip address
description link to GZA
no ip address
no ip address
no ip address
ip address dhcp
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip address 192.168.x.1 255.255.255.0
interface Vlan2
ip address 192.168.y.1 255.255.255.0
interface Vlan2
ip address 192.168.z.1 255.255.255.0
no ip http server
ip ssh version 2
control-plane
line con 0
line vty 0 4
login local
transport input ssh
transport output ssh
end
9 Replies 9
version 15.8
hostname C921
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
redundancy
ip dhcp pool LAN
dns-server 8.8.8.8
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
no ip http server
control-plane
vstack
line con 0
line vty 0 4
login
end
ben.r.fr
Hello @Georg Pauwen
Thank you very much for your answer, I will do it tomorrow as soon as possible.
- And to access several VLANs, I configure go0 and go1 as a trunk on the router and the same on the switches, could that be it?
- And I also create the VLANs on the switches according to their distribution on the ports?
I understand better how the router works now, again thank you very much and I will tell you how it works !!
Benjamin
ben.r.fr
Hello @Georg Pauwen,
ok thank you, I run the config and let you know
ben.r.fr
hello,
I think I forgot something or there is a configuration that blocks the dhcp attribution.
The SG250 does not seem to want to switch from operational mode to trunk mode
RZA : router c921-4P
GZA : switch SG250-26P
- int gi1 GZA (picture1) and int gi1 GZA switchport (picture 2) :
- int gi1 RZA switchport (picture 3) :
ben.r.fr
RZA (router) running-config :
RZA#sh running-config
Building configuration...
version 15.8
hostname RZA
boot-start-marker
boot-end-marker
enable password
no aaa new-model
ip dhcp pool vlan_
default-router 192.168.0.x
dns-server 8.8.8.8
dns-server 8.8.8.8
ip dhcp pool vlan_
dns-server 8.8.8.8
ip domain name
ip cef
no ipv6 cef
username  password 0
redundancy
no ip address
no ip address
no ip address
no ip address
ip address dhcp
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan2
no ip address
no ip http server
ip ssh version 2
control-plane
line con 0
line vty 0 4
login local
transport input ssh
end
version 15.8
hostname RZA
boot-start-marker
boot-end-marker
enable password
no aaa new-model
ip dhcp pool vlan_
dns-server 8.8.8.8
dns-server 8.8.8.8
ip dhcp pool vlan_
dns-server 8.8.8.8
ip domain name
ip cef
no ipv6 cef
username password 0
redundancy
no ip address
no ip address
no ip address
no ip address
ip address dhcp
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
interface Vlan2
interface Vlan2
no ip http server
ip ssh version 2
control-plane
line con 0
line vty 0 4
login local
transport input ssh
end
ben.r.fr
GZA (switchSG250) running-config :
GZA#sh running-config
config-file-header
GZA
v2.5.5.47 / RTESLA2.5.5_930_364_286
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end
unit-type-control-start
unit-type unit 1 network gi uplink none
unit-type-control-end
vlan database
vlan x-x,199
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone
voice vlan oui-table add 00036b Cisco_phone
voice vlan oui-table add 00096e Avaya
voice vlan oui-table add 000fe2 H3C_Aolynk
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone
voice vlan oui-table add 00e075 Polycom/Veritel_phone
voice vlan oui-table add 00e0bb 3Com_phone
bonjour interface range vlan 1
hostname GZA
username  password encrypted  privilege 15
ip ssh server
snmp-server server
ip telnet server
interface vlan x
name
interface vlan x
name
interface vlan x
name
interface vlan 199
name native
description link_to_RZA
spanning-tree link-type point-to-point
switchport access vlan 199
macro description switch
!next command is internal.
macro auto smartport dynamic_type switch
interface GigabitEthernet6
interface GigabitEthernet7
interface GigabitEthernet8
interface GigabitEthernet9
interface GigabitEthernet10
interface GigabitEthernet11
interface GigabitEthernet12
exit
ben.r.fr
It's all right
Very sincerely, I send you a huge thank you for your feedback as good as reactive and now I will continue the deployment.
If I can ask you if I have any questions, and above all thank you again a thousand times.
Benjamin
