Copying configs using SNMP command line
admin_2
Level 3
Level 3
Has anyone managed to copy a configuration to/from an IOS based router using SNMP set commands?
I've used the Cisco document below as a guide for using "Cisco-config-copy-mib-v1smi mib". I can't get the last SNMP set command to work -
"ccCopyEntryRowStatus.<Random number> integer 4".
I get the response "Reason: (badValue) The value given has the wrong type or length." from NET-SNMP 5.2.1 and a similar error from other applications.
After each attempt to snmpset the object, the router gets an SNMP "no such name" error".
I've tried this on a 1701 and 3640 router.
Cisco document describing the process:-
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094aa6.shtml
paddyxdoyle
Level 6
Level 6
I haven't used this for a while but i have used it from HPOpenview to routers and switches.
From my notes, i have recorded the create and go line as
nmpset -c 1.3.6.1.4.1.9.9.96.1.1.1.1.14.115 integer 1
Although the documentation does say 4, might be worth trying 1.
I'll have a quick look at the MIB when i get a minute to see if 1 exists, if it doesn't then i am not sure how i came up with that!
Paddy
Thanks for your comments but I get the same probem using integer 1 as for 4.
Any other suggestions?
I just tried it with success using the following syntax:
cd /tftpboot
touch router-config
chmod 777 router-config
snmpset -v 1 -c RW_String *.*.*.*.1.3.6.1.4.1.9.9.96.1.1.1.1.2.115 integer 1
snmpset -v 1 -c RW_String *.*.*.*.1.3.6.1.4.1.9.9.96.1.1.1.1.3.115 integer 4
snmpset -v 1 -c RW_String *.*.*.*.1.3.6.1.4.1.9.9.96.1.1.1.1.4.115 integer 1
snmpset -v 1 -c RW_String *.*.*.*.1.3.6.1.4.1.9.9.96.1.1.1.1.5.115 ipaddress "*.*.*.*"
snmpset -v 1 -c RW_String *.*.*.*.1.3.6.1.4.1.9.9.96.1.1.1.1.6.115 octetstring "router-config"
snmpset -v 1 -c RW_String *.*.*.*.1.3.6.1.4.1.9.9.96.1.1.1.1.14.115 integer 1
$ ls -la route*
-rwxrwxrwx 1 pjdoyle other 1934 Apr 4 13:40 router-config
$ head router-config
! No configuration change since last restart
version 12.0
service timestamps debug uptime
service timestamps log datetime
service password-encryption
I initially tried it using an integer of 4 on the last bit and it didn't work, must be the SNMP version bit thats giving your problems.
Rgds
Paddy
Interestingly, if you try the last line using version 2, it still only works with integer 1
$ snmpset -v 2c -c RW *.*.*.* .1.3.6.1.4.1.9.9.96.1.1.1.1.14.115 intege
r 1
cisco.ciscoMgmt.ciscoConfigCopyMIB.ciscoConfigCopyMIBObjects.ccCopy.ccCopyTable.
ccCopyEntry.ccCopyEntryRowStatus.115 : INTEGER: active
Good Luck
Paddy
