Correctly Shut Down / Power Off IPS-4240-K9 from Shell Command Line
mstevensuk
Hello
Apart from turning of the power switch, how do you correctly Shut Down / Power Off a IPS-4240-K9 from a Shell Command Line?
Mike
Marvin Rhoads
From the sensor cli, you can issue the following command:
sensor# reset powerdown
You can also do the same from IDM or IME GUI management.
Source: step 2 in the following installation guide section:
http://www.cisco.com/c/en/us/td/docs/security/ips/interface_cards/19056_01.html#wp39058
Marvin Rhoads
