CWLMS and CSPM installation on single machine
vtandon
Hi team,
I need to install CWLMS3.0 and CSMP3.1 on WIndows at my client side. I asked for two seperate server from client for the same.
Client is insisting to install both on the same machine, as it would be cost effective for him. Please suggest is it feasible.
Thanks in advance.
robv
Can you virtualize the servers onto one piece of hardware?
Hi Roby,
There are the tools available which can virtually split one physical server into two logical device. It is similar to PIX firewall Active-Active configuration.
