ā01-10-2012 02:59 AM
I need some help about the DCNM installation :
ā01-10-2012 05:47 AM
The Release Notes are usually a good place to check these questions. Unfortunately they are silent on your specifc question. I'd suggest the TAC should be able to give you a definitive answer.
ā10-04-2012 10:37 AM
Hi a.perrichon,
have you the answer today ? I am facing the same issue today.
Thanks by advance,
Abel
ā10-08-2012 02:16 AM
Finally, the DCNM soft is still remained in its box So Soory, I have no more information.
ā10-08-2012 12:47 PM
I'm unsure of the version you are trying to install but here are the requirements for 5.x
Cisco DCNM Release 5.0(2) supports running the Cisco DCNM server on these operating systems:
ā¢
Microsoft Windows Server 2003 Enterprise Edition, Service Pack 1 and Service Pack 2 (32-bit, 64-bit).
ā¢
Red Hat Enterprise Linux Release 5.4 (32-bit and 64-bit versions).
And here is 6.1
Cisco DCNM Release 6.1(x) supports running the Cisco DCNM-LAN and Cisco DCNM-SAN servers on these operating systems:
ā¢
Microsoft Windows 2003, 32-bit or 64-bit with Service Pack 2
ā¢
Microsoft Windows 2008 Standard and R2 (32-bit and 64-bit)
ā¢
Red Hat Enterprise Linux Release 5.6 and 5.7 (32-bit and 64-bit) or a lower version
Note
If a service pack for the Windows operating system is not listed, the service pack is not supported.
Hope that helps.
