DFM highutilization events, why?
fwim
Hi there,
I hope someone can spread some light on the following.
We often get dfm highutilization events like the these for vg248 devices:
EVENT ID = 0001OSG
ALERT ID = 0000DPO
TIME = Thu 22-May-2008 07:13:46 CEST
STATUS = Active
SEVERITY = Critical
MANAGED OBJECT = 172.20.24.28
MANAGED OBJECT TYPE = Voice and Telephony
EVENT DESCRIPTION = HighUtilization::Component=IF-172.20.24.28/1 [Ethernet adapter] [172.20.24.28];OutputPacketRate=3.7 PPS;Type=ETHERNETCSMACD;CurrentUtilization=1.22978296E11 %;InputPacketRate=3.8733335 PPS;TrafficRate=1.53722871E16 BYPS;UtilizationThreshold=40;DuplexMode=FULLDUPLEX;MaxSpeed=100000000;
When looking at the currentutilization rate being displayed, I'm not able to match this with the UtilizationThreshold setting
that should trigger such an event. Does someone know why we are getting these events with CurrentUtilization
figures like these?
Any help is much appreciated!
Joe Clarke
We've seen this from time to time with DFM. The reason the event gets generated is that DFM thinks the utilization is 1.53x10^16 Bps or 1.23 x 10^11% (123,000,000,000%). This problem could be caused by a counter rollover, or a bug in DFM. We've been tracking a few such customer cases. You might want to contact the TAC about this.
