DNS MONITORING
pradorock
Greetings Network Gurus
I and doing a little research for my masters, I am going to monitor the DNS queries generated between my computer and a server as I try to install some software. Which program can I use to monitor dns packets as the devices communicates. Wiresshark is not ok
Collin Clark
Any packet analyzer software will work. If the traffic is going through a router or ASA you can do a packet capture directly the device.
