Enabling/Disabling traps and logging per interface by SNMP
HorstRitter
The OID IF-MIB::ifLinkUpDownTrapEnable (1.3.6.1.2.1.31.1.1.1.14) enables you to set or disable the parameter "snmp trap link-status" per Interface.
To do so, you have to invoke the following command:
snmpset -v2c -c write_community <IP address> ifLinkUpDownTrapEnable.8 i disabled # equivalent to "no snmp trap link-status"
IF-MIB::ifLinkUpDownTrapEnable.8 = INTEGER: disabled(2)
snmpset -v2c -c write_community <IP address> ifLinkUpDownTrapEnable.8 i enabled # equivalent to "snmp trap link-status"
IF-MIB::ifLinkUpDownTrapEnable.8 = INTEGER: enabled(1)
To crosscheck if everything went fine, you can invoke a snmpget for the specific interface or "sh run int f0/8"
snmpget -v2c -c read_community <IP address> ifLinkUpDownTrapEnable.8
View on an interface with disabled trap:
interface FastEthernet0/8
switchport access vlan nnn
switchport mode trunk
storm-control broadcast level 65.00 55.00
storm-control multicast level 65.00 55.00
mdix auto
spanning-tree portfast
end
View on an interface with enabled trap:
mdix auto
end
So far, so good.
Now, I would like to enable/disable additional logging settings; certainly as well by SNMP (as described above). Unfortunatelly, eventough I've checked plenty of MIB's, I cannot find any OID for the following settings:
logging event status
logging event link-status
logging event spanning-tree status
I cannot imagine that there is an OID for "snmp trap link-status" but not for those mentioned above.
Many thanks in advance for any advice.
Horst Ritter
Joe Clarke
There is not. You could do this, though, using the CISCO-CONFIG-COPY-MIB to upload a config snippet to this device which would add the desired config to each port. See this tech tip for more details:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_configuration_example09186a0080094aa6.shtml
Essentially, you'd have a snippet like:
int fa0/8
no logging event link-status
end
And you'd push that to the device using SNMP-triggered TFTP.
