Front Panel Views in Network Assistant are Incorrect
swindonsilicon
Hi, I am having problems with the network assistant not showing the front panel view's correctly when connecting to our stack of 3850's. As can be seen in the attached image of 3 switches they show that identical ports are enabled on each one.  Switch number 3 should actually be all grey as no devices are connected to this new member.  The Network Assistant Version is 6.1,  Is there a way of fixing this?
Phil
Cisco 3850 Front Panel View
0 Replies 0
