Generate RSA keys on C1000 automatically
TBNLSB
Hello, I am trying to configure a solution to have ZTP on Catalyst 1000, but the issue I'm facing is that I cannot find a way to automatically generate RSA keys.
EEM is not available on C1000 and just putting it in the startup config does not work.
I also tried using macro's but that didn't work either.
The only way I can find is trough Ansible where it connects through serial. But I would also like to update the device to the latest firmware, and sending files over serial takes a long time.
So does anyone have other ideas or suggestions?
0 Replies 0
