How can I monitor vlan traffic on trunk port via SNMP?
David Kleberson
Is there a way to monitor per VLAN traffic on a trunk port using PRTG? I can monitor overall traffic o a physical port but I need per VLAN traffic monitoring. Thank you!
CISCO8006
Maybe you can enable netflow - on PRTG define a custome Netflow and match the VLAN ID's
Is there a way to do it with SNMP?
I don't think so
