How to get authentication sessions interface data using SNMP oid?
Naiem Rahman
Trying to get the authentication sessions information using for end device connected to switch. Using the command below I can get the authentication sessions info. for the endpoints connected to the port. I am looking to get this similar information using SNMP command and the oid I need to get those information
>> show authentication sessions interface Gi8/0/35 details
Interface: GigabitEthernet8/0/35
IIF-ID: 0x12CF0091
MAC Address: xxxx.xxxx.xxxx
IPv6 Address: Unknown
IPv4 Address: 10.xx.xx.xx
User-Name: xx-xx-xx-xx-xx-xx
Status: Authorized
Domain: DATA
Oper host mode: multi-auth
Oper control dir: both
Session timeout: 43200s (server), Remaining: 36852s
Timeout action: Reauthenticate
Acct update timeout: 172800s (local), Remaining: 23375s
Common Session ID: 1B00020A0000033658CE82EF
Acct Session ID: 0x0000027e
Handle: 0xb800024a
Current Policy: xyz
Server Policies:
Session-Timeout: 43200 sec
Vlan Group: Vlan: 200
ACS ACL: xACSACLx-IP-PERMIT_ALL_IPV4_TRAFFIC-57f6b0d3
SGT Value: 19
Method status list:
Method State
dot1x Stopped
mab Authc Success
pieterh
try this link to search for the desired fields  Cisco SNMP Object Navigator
you probably need multiple queries to retrieve all the fields above
