How to get the router to monitor the interface
Earl Granger IV
I need to know how to create an applet to monitor an interface and if it recieves a specific IP do a shut no shut on the interface.
-Earl
Joe Clarke
You could use ACLs for this.  Apply an inbound ACL on the interface with logging enabled.  It could be as simple as:
access-list 100 permit ip any any log
int gi0/0
ip access-group 100 in
Then, when you get a hit, that will generate a syslog message that your EEM policy can react to:
event manager applet watch-ip
event syslog pattern "list 100 .*10.1.1.1"
action 1.0 cli command "enable"
action 2.0 cli command "config t"
action 3.0 cli command "int gi0/0"
action 4.0 cli command "shut"
action 5.0 cli command "end"
Cool, thanks.  I would need it to do a no shut as well.  Thanks
