how to mange blade switch on LMS 2.6
eliaspaulos
I have new blade switch, with 5 blades, actually they have one host name.however in ciscoworks the 4 blades detected as device with ip address belongs to them, and showed as failed devices and unmanageable. should I removed this blades from DCR and added them on exclude list?
frankzehrer
Level 4
Level 4
Hi Elias,
i guess most members of the forum are not fortune tellers and therefore cannot have a look into the crystal ball to determine your blade switch type.
Please be a bit more precise:
What kind of chassis?
What kind of blades?
What is the used IOS or CATOS?
What Version of the LMS do you use??
And as generic answer: Yes you can add them to the exclude list and then they will not discovered anymore.
Best regards,
Frank
