Ip address
Kenny_Jovanca
can anyone recommend me IP address for all the devices?
thanks
Georg Pauwen
there are a lot of mistakes in your IP addressing. What instructions are you following ? To start out, make sure the default gateways are reachable from each device.
Georg Pauwen
what instructions are you following, what are the requirements ? As long as there are no overlapping IP address spaces, you can use any address you wish.
Post the zipped Packet Tracer project (.pkt) file, and indicate which version of Packet Tracer you are using.
Kenny_Jovanca
Is this Ip fine?
cause some pc can't ping other pc from different server
Im using version 8.1.1.0022
https://drive.google.com/file/d/1MPiX0GR7mMpTuhUEe9SH-O2Rmj5s4ZqO/view?usp=sharing
Georg Pauwen
Kenny_Jovanca
this are the requirement
google.com server ip: x.x.x.35/29
router ethernet 1 ip: x.x.x.34/28
nb3@gmail.com ip: x.x.x.193/28
