04-27-2022 08:10 PM
04-28-2022 04:22 AM
there are a lot of mistakes in your IP addressing. What instructions are you following ? To start out, make sure the default gateways are reachable from each device.
04-28-2022 01:21 AM
what instructions are you following, what are the requirements ? As long as there are no overlapping IP address spaces, you can use any address you wish.
Post the zipped Packet Tracer project (.pkt) file, and indicate which version of Packet Tracer you are using.
04-28-2022 04:09 AM
Is this Ip fine?
cause some pc can't ping other pc from different server
Im using version 8.1.1.0022
https://drive.google.com/file/d/1MPiX0GR7mMpTuhUEe9SH-O2Rmj5s4ZqO/view?usp=sharing
04-28-2022 04:22 AM
04-28-2022 05:12 AM
this are the requirement
google.com server ip: x.x.x.35/29
router ethernet 1 ip: x.x.x.34/28
nb3@gmail.com ip: x.x.x.193/28
