Issues with Netflow on IOS-XE
Nikolaos Milas
We have a Cisco 3650 with IOS-XE v03.03.05SE configured as border router, and running IP Services.
Our problem is that netflow data for virtual interfaces (VLANs) are not exported with their respective ifindex.
All physical links are trunk and VLANs (on subinterfaces) are used for actual terminations.
Netflow (v9) is configured as follows (using Flexible Net Flow - FNF):
    flow record CiscoXE1
      match ipv4 tos
      match ipv4 protocol
      match ipv4 source address
      match ipv4 destination address
      match transport source-port
      match transport destination-port
      match interface input
      collect transport tcp flags
      collect interface output
      collect counter bytes long
      collect counter packets long
      collect timestamp absolute first
      collect timestamp absolute last
    flow exporter ipv4exporter
      destination 195.251.204.<removed>
      source Loopback0
    flow monitor ipv4monitor
      cache timeout active 15000
      record CiscoXE1
    vlan configuration 4,8,25,102,133,135
    ip flow monitor ipv4monitor input
Here is some sample raw data received on the collector (last octet of ip addresses has been replaced with xxx):
    Flow Record:
       Flags        =              0x06 FLOW, Unsampled
       export sysid =                 4
       size         =                64
       first        =        1461155049 [2016-04-20 15:24:09]
       last         =        1461155049 [2016-04-20 15:24:09]
       msec_first   =               154
       msec_last    =               154
       src addr     =   195.251.204.xxx
       dst addr     =   194.177.210.xxx
       src port     =             46462
       dst port     =                53
       fwd status   =                 0
       tcp flags    =              0x00 ......
       proto        =                17 UDP
       (src)tos     =                 0
       (in)packets  =                 1
       (in)bytes    =                61
       input        =                27
       output       =                 0
    Flow Record:
       export sysid =                 4
       size         =                64
       first        =        1461155039 [2016-04-20 15:23:59]
       last         =        1461155063 [2016-04-20 15:24:23]
       msec_first   =               154
       msec_last    =               154
       src addr     =   195.251.203.xxx
       dst addr     =     183.3.202.xxx
       src port     =                22
       dst port     =             60979
       fwd status   =                 0
       tcp flags    =              0x1b .AP.SF
       proto        =                 6 TCP
       (src)tos     =                 0
       (in)packets  =                22
       (in)bytes    =              3413
       input        =                 3
       output       =                 0
If I understand right, input/output fields in flow records should contain the ifindex of the interface. It seems that the physical interface ifindex is recorded rather than the vlan ifindex.
Is there something wrong with the above configuration?
For your information and as an example, here is the setup of the main (virtual) interface, VLAN 102 which is the transfer channel from/to the ISP:
! The physical interface (ifindex 27)
interface GigabitEthernet1/1/1
 description === EDET LINE ===
 switchport mode trunk
 spanning-tree bpdufilter enable
! The virtual interface (ifindex 43)
interface Vlan102
 ip address <removed> 255.255.255.254
 ip access-group 100 in
 ip access-group 101 out
 no ip unreachables
 no ip proxy-arp
 ip verify unicast reverse-path 103
 ipv6 address <removed>
 ipv6 enable
Note: If I try to configure netflow in the "conventional" way, it's not possible:
    (config)# interface vlan 102
    (config-if)#ip flow monitor ipv4monitor input
    % Flow Monitor: Flow Monitor 'ipv4monitor' flexible netflow not supported on vlan interfaces
It seems to be only possible to configure netflow in "vlan configuration" mode, as I have done.
So, how the vlan interface ifindex can be included in netflow export?
Any ideas or suggestions please?
Thanks in advance,
Nick
Nikolaos Milas
I have now modified configuration as follows:
flow record ipv4-xe-1
 match ipv4 version
 match ipv4 tos
 match ipv4 ttl
 match ipv4 protocol
 source Loopback0
 record ipv4-xe-1
Now I see that seemingly most flows include an "input" field value of 33, which I understand corresponds to:
#show snmp mib ifmib ifindex | i 33
StackSub-St1-2: Ifindex = 33
FYI, the physical topology is:
Interface                      Status         Protocol Description
Vl1                            admin down     down
Vl4                            up             up       *** Wireless Link 1 - Data-Channel ***
Vl8                            up             up       *** Wireless Link 2 - Data-Channel ***
Vl25                           up             up       *** UPLINK TO INTERNAL NET (FW DEVICE) ***
Vl102                          up             up       *** TO ISP ***
Vl133                          up             up       *** L2VPN TO CAMPUS 2 ***
Vl135                          up             up       *** L2VPN TO CAMPUS 3 ***
Gi0/0                          down           down
Gi1/0/1                        up             up       ETHERCHANNEL TO INTERNAL NET - MEMBER 1
Gi1/0/2                        up             up       ETHERCHANNEL TO INTERNAL NET - MEMBER 2
Gi1/0/3                        up             up       ETHERCHANNEL TO INTERNAL NET - MEMBER 3
Gi1/0/4                        up             up       ETHERCHANNEL TO INTERNAL NET - MEMBER 4
...                        down           down
Gi1/0/11                       up             up       *** WiFi UPLINK 1 ***
Gi1/0/12                       up             up       *** WiFi UPLINK 2 ***
...                        down           down
Gi1/1/1                        up             up       *** ISP LINK ***
...                         down           down
Po1                            up             up       *** ETHERCHANNEL TO INTERNAL NET ***
Lo0                            up             up
But what interface does this "StackSub-St1-2: Ifindex = 33" correspond to?
And finally ...how can we include vlan ifindexes in flows?
All my experiments have been fruitless.
Please advise.
Nick
