Kernel error on Nexus 7000
vedanupcisco
I work in an organization where we recently upgraded our core switches to Nexus 7000. Everything is set up well but we still keep getting this annoying message when we log in the switch. Also the time taken to login into the switch (ssh and telnet) is longer than normal. It is not affecting the network in any way but my concern is somewhere something is wrong and it will give us trouble in the future. Can anyone help me troubleshoot the cause of this error message.
Error message:
2011 Oct 21 11:41:37 Nexus-RH325 Oct 21 11:41:37 %KERN-2-SYSTEM_MSG: EXT3-fs error (device hde1) in start_transaction: Journal has aborted - kernel
2011 Oct 21 11:41:39 Nexus-RH325 %DHCP_SNOOP-6-DHCPPKTFWD: Gracefully forwarding DHCP packet. Reason: Relaying the DHCP pkt on intf: 0x9010020
2011 Oct 21 11:41:48 Nexus-RH325 %DHCP_SNOOP-6-DHCPPKTFWD: Gracefully forwarding DHCP packet. Reason: Relaying the DHCP pkt on intf: 0x90100f0
2011 Oct 21 11:41:48 Nexus-RH325 Oct 21 11:41:48 %KERN-2-SYSTEM_MSG: EXT3-fs error (device hde1) in start_transaction: Journal has aborted - kernel
2011 Oct 21 11:41:52 Nexus-RH325 %DHCP_SNOOP-6-DHCPPKTFWD: Gracefully forwarding DHCP packet. Reason: Relaying the DHCP pkt on intf: 0x90100f0
2011 Oct 21 11:41:52 Nexus-RH325 %DHCP_SNOOP-6-DHCPPKTFWD: Gracefully forwarding DHCP packet. Reason: Relaying the DHCP pkt on intf: 0x90100a0
2011 Oct 21 11:41:52 Nexus-RH325 Oct 21 11:41:52 %KERN-2-SYSTEM_MSG: EXT3-fs error (device hde1) in start_transaction: Journal has aborted - kernel
Any help is appreciated.
Andre Scheepers
Experiencing the same message.  Doesn't appear to be causing any impact.
Oleksandr Nesterov
This message says that there is an error on writing on logflash system.
You can do following:
1. format logflash using command:
#format logflash: check-filesystem
2. replace flash card with new one (RMA for example)
HTH,
Alex
Replaced flash card.  Issue resolved.  Thanks Oleksandr.
