Linksys router, problems with SNMP
jdamone
We have several Linksys RVL200  routers out in the field. They work fine except now we want to enable SNMP to  monitor bandwidth usage with PRTG Network Monitor. I’m having a problem with a few of these getting SNMP  to work properly.
I’ve configured all the devices  exactly the same, however some of them will not display the Ethernet sensors to  monitor bandwidth properly.
I believe we have the latest  firmware installed (v1.1.7).
I’ve done some onsite testing with  an SNMP tester and the results are the same.
Do you have any suggestions on how I  can proceed?
Thank  you,
John
0 Replies 0
